Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - This may sound like a REAL STUPID question
Old 06-04-2003, 11:43 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
Your fenders are undercoated. Usually a dealer option on new cars that they charged $$$$$$$$$$ for. You just need to get rough with the bolts, no easy way around it. They are probably corroded as well as gobbed up with tar. Can you get a small wire wheel on your drill up there? That would knock off the tar and shine the bolt heads so your wrench will go right on.
