Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - This may sound like a REAL STUPID question
Old 06-05-2003, 08:15 PM
asennad asennad is offline
If you have a plumbers propane torch you can use that to remove the undercoating from the bolts.
Once the goo is gone try soaking the nut in penetrating oil for a day or two.
If that doesn't work heat up the nuts and touch a wax candle to the nut. The heat sucks wax in the threads and can help the nut come off a little easier.
