This may sound stupid,.....but - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2005, 12:15 PM
tazzman68's Avatar
Justa Freak!
does anyone know what all the 1/2 in steel lines coming out of my tranny, and tranny pan are? This is my 1967 F100. I need to figure out what their purposes are, I'm installing headers, and these tubes are kinda in the way. And i don't want to do anything to them without knowing for sure what they are.
Old 01-31-2005, 12:22 PM
poncho62's Avatar
Wiki Edits: 5
They are coming out above the pan and are the trans cooling lines. They go up to the front to the rad. You can move them, but don't remove them..........or break them.
Ontario Rodders
Old 01-31-2005, 12:37 PM
tazzman68's Avatar
Justa Freak!
that is what i thought, but I swear , one actually comes out of the pan itself on the driverside, and it appears to go into the engine block. I will study their routing a little better when i get home from work tonight. The other thing is the size of these lines, they are HUGE, like over a 1/2 in in diameter, and no i'm not looking at the ends, this is actually the tube daimeter itself.. No where near the miniscule size of tranny cooler lines. And they don't goto the radiator.
Old 01-31-2005, 12:40 PM
poncho62's Avatar
Wiki Edits: 5
?????....a picture might help.
Ontario Rodders
Old 01-31-2005, 12:42 PM
tazzman68's Avatar
Justa Freak!
I was wondering about that, i will break out the digital when i get home, and get some shots of these mystery tubes.
Old 01-31-2005, 03:44 PM
If they are cooler lines one should come out of the transmission body, the other may go into the pan. Are you sure that you are not looking at the distick/filler tube?
Old 01-31-2005, 06:01 PM
Crosley's Avatar
Wiki Edits: 1659
what chazmac said.
gotta be cooler lines and the pan fill tube.
I'd leave them alone.
Old 02-01-2005, 06:38 AM
stu stu is offline
But he states this.
" one actually comes out of the pan itself on the driverside "
Filler tubes are on the passenger side.
Old 02-01-2005, 06:45 AM
cboy's Avatar
Last journal entry: Finished
There's any outside chance he is looking at the downshift rod - which looks like a tube and attaches on the driver side near the pan and then extends upward so it might appear, looking from below, that it attaches to the block. It's the only thing I can think of that would be in that position on a stock Ford auto tranny.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
poncho62's Avatar
Wiki Edits: 5
Me thinks we need a picture................
Ontario Rodders
Old 02-01-2005, 07:01 AM
stu stu is offline
Me thinks we need a picture too.
Old 02-01-2005, 09:54 AM
tazzman68's Avatar
Justa Freak!
Ok, I did NOT get a chance tyo go get pics of it last night, had to go get a load of firewood instead. I will get and post pictures tonight.
BTW I decoded my data plate, and the transmission code is a G, which translates to "automatic"
Well, the guys over at Fordification figured it out, my truck came factory with a heat exchanger, and they may have the instructions on how to reroute those tubes. I am still gonna post pics so that people can get a better visual as to what I was talking about.
Old 02-01-2005, 11:25 AM
stu stu is offline
Probably an oil cooler.
Old 02-01-2005, 01:31 PM
tbirdscott's Avatar
stuff'n things'n whatnot
Old 02-01-2005, 04:24 PM
tazzman68's Avatar
Justa Freak!
Ok, i finally have a definite answer. I have a water cooled transmission! the guys over at fordification figured it out at about the same time as an old timer at the local ford dealer. I'm still not too sure as to which trans I have, but at least I now know what those lines are for. I will still post pics to show everyone as soon as I have a chance to take them. Hopefully tonight.
