Maybe a dumb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2013, 06:40 AM
ramtuff's Avatar
Safety Is Job 1
I was told to diconnect the negative cable from battery and use a DVOM to trce the short I'm still having problem with on a 2000 Dodge Ram 1500. I did this and using the negative - probe to battery + side and the red probe+ to checked fuses. The only thig is, it is showing power still running in all fuse sockets. And I did let it set for a day before preforming test. The dumb question I have is: Could a bad ground - be causing the high spark issue? Thanks to any & all answers
Old 02-03-2013, 06:52 AM
gearheadslife's Avatar
MentalMuffinMan
I like to use a test light, between the battery post and cable..
if there is a draw, it lights up..
then I pull fuses one at a time.. leaving the radio fuse out, as the memory /clock will draw a little, and making sure the switch for the door open/closed lights.. is off..
and when test light goes out. you found the curcuit that has the short..
Old 02-03-2013, 07:07 AM
ramtuff's Avatar
Safety Is Job 1
Ok gearheadslife, I'll try that. Between you and I, I'd like to take these engineers and do a St. Valentines massacre on them. Making this so hard on the average joe to fix something
Old 02-03-2013, 07:13 AM
ramtuff's Avatar
Safety Is Job 1
If this doesm't work...I'm invitining everyone to a buring Dodge p/u bon fire.....bring hot dogs and marshmallows
Old 02-03-2013, 07:33 AM
electrical
I finally sold my 98 Ram because of an electrical draw that I could never find. If I didn't drive it for a day the battery would be dead. Got tired of endless searching and sold it! I think the engineers at the big 3 should be made to work on the crap they design...it may inspire them to make things differently.
Old 02-03-2013, 11:50 AM
LATECH's Avatar
Aside from radio memeory circuit which is allways hot, and the dome lights/glove box light.....the big wire on the alternator needs to be disconnected as part of the test. If the alternator has a diode that is weak it will draw current.
My money is on the radio memory circuit.
I got your PM but to answer your questions it is best to do so here in the forum as everyone will benefit from the posts, not just one person.
The PCM can also develop a undesireable amount of parasitic draw as well, so dont forget to check there.
Fact is stranger than Fiction
Old 02-03-2013, 06:33 PM
EOD Guy's Avatar
X2 on the radio...... I've fixed two circuit draws...... in was the amp inside the radio on one and the external amp on the other. Now one of the first tests I do is unplug the radio connector.
dumb dumb wheel question...5 lug steel rim? MUSTISIXSTANG Suspension - Brakes - Steering 4 06-07-2010 07:27 AM
Dumb question!! hemi43 Hotrodders Site Suggestions and Help 11 11-25-2006 07:29 AM
i have a dumb question awditlady Engine 1 07-02-2006 01:22 PM
another dumb question swoodard23 Body - Exterior 8 08-18-2005 03:53 AM
dumb question Sub_Urban_454 Engine 2 11-01-2003 08:57 AM
