maybe a silly question but... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2006, 02:21 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
gonna try a used 9inch member/gears so.. how do i check... what the number of spline is.. do i literally just count the spline on the axle ends .. or is there another way? Also.. when i check out the pod do i just eyeball the teeth for chips and check the rest for cracks ? and lastly .... will any 9inch center section fit any 9inch rear end.. i have the smaller tapperd axle tubes(probably 28spline) and the donor will probably be from a mid 70's ford pickup .
Thanks lots folks
bill
Old 03-11-2006, 02:40 PM
Twistedwrench's Avatar
No officer I won’t do it again
I think this link will help.
http://www.kevinstang.com/Ninecase.htm
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
