Maybe torque converter gone bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2004, 08:28 PM
Got another buick here and when I step on the gas in drive the car just creeps along until it finaly picks up speed, but its not a sudden pick-up, its more of a smooth-slow pickup.
It's odd, because The engines RPM doesnt seem to affect it much. Example, if I just lightly step on the gas, the car will creep up to speed, but if I put a little more gas into it, the RPMs go up, but the speed increase is still the same. Sometimes it feels like it doesnt stall until 3000RPM or so. The transmission goes through all 4 forward gears fine, it's just getting the thing up to those higher speeds.
So what do ya think it sounds like? Torque converter? The factory stall is around 2000, so something is not right.
Thanks.
Old 06-02-2004, 12:44 AM
Sounds like a possible owc failure in the torque converter.
Old 06-02-2004, 01:16 AM
Thanks for the reply.
Yeah something just doesnt seem right with it, driving it some more and the trans shifts fine from gear to gear, but the fact I can put my foot down on the pedal and watch the RPMs go up, but only accelerate slowly, its a weird feeling. Especially when I go and put my foot down lightly and it accelerates at the same pace as when I mash it. Strange feeling.
Old 06-02-2004, 07:35 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Stupid question perhaps, but have you checked the fluid level. My TH350 developed a leak while setting parked on a hill out the tail shaft once. It did the same thing, but was because of obvious oil level problems. Luckily I checked it and found the problem.
Chris
Old 06-03-2004, 09:39 AM
Yeah, I checked the level and it was fine, kind of a dark red though(like blackish red). Gonna change the O-ring, filter and fluid in a day or two, see if it helps at all.
Old 06-03-2004, 07:52 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Is that a new acronym for a stator clutch?
What will they think of next........
I wouldn't doubt that the clutch is fine, but the stator itself is chunked up.
Old 06-03-2004, 09:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I kinda thought he meant ORC ............Over Run Clutch in the stator of the converter
I gotta sign this too?
Tony
