MC for disc/disc with 7" booster? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2007, 10:38 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Looking for a donor setup for my 41. Can't be bigger than 7" to fit under the hood. I have 4 wheel drums, so I can use Disc/disc (or Drum/drum, but that appears to be impossible), just not the typical Disc/drum that's so easy to find. Anyone happen to know which cars came with Disc/Disc? Assume it would have to be a ricer to have the small booster.
Old 05-14-2007, 11:15 AM
How about a Chevette ...
Yes, I said Chevette, not Corvette ...
A few of the nicer Chevettes had a Power Brake Booster and they are 7 inch diameter. The master cylinder is for disc on the front and drums on the rear.
I forget the exact year. I robbed the entire setup ... booster, M/C and pedal ... used it in a early F1 pickup.
Old 05-14-2007, 11:57 AM
oldguy829's Avatar
Wiki Edits: 88
re: MC for disc/disc with 7" booster?
Deuce. I hear you. I have the complete setup from a chevy Metro. Fits great, easy mods, but it is also the disc/drum setup. What i'm hoping is, someone can tell me which cars had optional all wheel disc brakes, so I could hunt one of them down.
Old 05-14-2007, 03:33 PM
staleg's Avatar
Last journal entry: Hand brake
Many cars had the same MC for disc/disc and disc/drum setup. They just used another combination valve.
See for example the typical Corvette MC that som many rodders use. It's the same MC no matter what set up they use. It is the combination valve who differ.
Old 05-14-2007, 05:12 PM
Will I ever get it done?
Last journal entry: Hood
To put the disc/drum MC on a drum/drum, you will need to add a 10 lb. residual pressure valve for the front brakes.
MC Que. with booster 39chevy Suspension - Brakes - Steering 1 12-31-2006 01:04 PM
7" dual diaphragm Booster Silverfox031 Suspension - Brakes - Steering 1 07-07-2006 01:34 PM
brake booster size pigjamelectric Suspension - Brakes - Steering 3 05-08-2005 08:44 PM
69 Pontiac Brake Booster Problem.. jboy Suspension - Brakes - Steering 8 07-22-2004 10:59 AM
7" booster Al Suspension - Brakes - Steering 2 03-03-2003 12:15 PM
