-   -   Mc Problem But whats the diagnoisis (http://www.hotrodders.com/forum/mc-problem-but-whats-diagnoisis-174409.html)
GeoGuy96 03-12-2010 05:53 PM
So i got a 96 geo and it has a Mc problem, so the problem is is that i get ampul power to brake but the brakes press down on the rotors constintly my question is , is it electrical or is it just need a new Mc cuz the idiot b4 thought he knew eletrical and he doesnt
cobalt327 03-12-2010 07:55 PM
If you are hearing a constant grinding sound- but the brakes are not actually dragging- the first thing to check, is to see if the wear indicators built into the brake pads are rubbing the rotor. This is a warning to prevent you from continuing to drive w/the pads too worn.
If you DO continue to drive, and providing this is the 'problem', the pads WILL destroy the rotors.
If the brakes ARE truly rubbing, they will overheat and smell as well as basically quit working from excessive heat/fade in a relatively short period of time.
In ANY event, it is time to look at the whole brake system- or have them looked at- before you tear up expensive parts or kill someone.
Good luck.
deadbodyman 03-13-2010 08:24 AM
almost sounds like the calipers are froze
68NovaSS 03-13-2010 10:08 AM
How bad are they dragging? Unless it has a takeup MC, expect them to rest on the rotor lightly.
fast68 03-14-2010 04:27 AM
sounds like frozen calipers to me
did they cut back english classes in MN?
just wondering,
good luck!
