Mc Problem But whats the diagnoisis - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2010, 06:53 PM
So i got a 96 geo and it has a Mc problem, so the problem is is that i get ampul power to brake but the brakes press down on the rotors constintly my question is , is it electrical or is it just need a new Mc cuz the idiot b4 thought he knew eletrical and he doesnt
Old 03-12-2010, 08:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you are hearing a constant grinding sound- but the brakes are not actually dragging- the first thing to check, is to see if the wear indicators built into the brake pads are rubbing the rotor. This is a warning to prevent you from continuing to drive w/the pads too worn.
If you DO continue to drive, and providing this is the 'problem', the pads WILL destroy the rotors.
If the brakes ARE truly rubbing, they will overheat and smell as well as basically quit working from excessive heat/fade in a relatively short period of time.
In ANY event, it is time to look at the whole brake system- or have them looked at- before you tear up expensive parts or kill someone.
Good luck.
Old 03-13-2010, 09:24 AM
deadbodyman's Avatar
Wiki Edits: 11
almost sounds like the calipers are froze
Old 03-13-2010, 11:08 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
How bad are they dragging? Unless it has a takeup MC, expect them to rest on the rotor lightly.
Semper Fi
Old 03-14-2010, 05:27 AM
fast68's Avatar
likes chevy trucks & boobies
sounds like frozen calipers to me
did they cut back english classes in MN?
just wondering,
good luck!
help troubleshooting 89 350 TBI problem? Chuck78 Engine 14 09-15-2013 07:32 AM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 09:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 01:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 04:44 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 04:48 PM
