Mcgard wheel lock removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2010, 04:20 PM
I bought a Mac tools Lt 4000 hubcap and wheel lock removal tool used off of E Bay, problem is, there are no instructions and none of the tools in the box seem to fit the Mcgard locks they are supposed to remove ! Anyone know which tool and if it is supposed to be hammered on???
Old 01-15-2010, 06:31 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Yes, you have to hammer them on, and the splines/threads are reversed, like an Easyout. If it's a hardened lock, even the tool may not get it off though. I've got 4 of those tools, that fit 8 different sizes (double ended), and still there are some I have to take off the old fashioned way,
Old 01-15-2010, 07:21 PM
I had this problem several years ago. I had bought a used truck with McGuard wheel locks and the key was lost. The truck had aluminum slot wheels, and I didn't want to damage them. I got a lug nut, held it against the end of the wheel lock, and welded through the hole in the lug nut with a stick welder. The heat had the added bonus of helping to loosen the lock, and I was able to remove it easily.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
1964 Impala - Trunk Cylinder Removal 64Joker Hotrodding Basics 7 09-15-2009 02:44 PM
700r4 lock up confusion jrs22166 Transmission - Rearend 4 07-28-2009 08:35 AM
steering wheel lock removal wave1957 Suspension - Brakes - Steering 3 03-05-2008 09:33 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
