The way you did it is the way I do it and it works for me.
After measuring, I bring the piston to TDC and check how far down in the hole it is and subtract the difference from the total. |
Your pistons might be rocking at either the top or bottom of the rotation, causing your measurements to be skewed a little as they are showing. If you could check the piston in the very center of the bore, where piston rock would be negligable, you will see a stroke more consistant with what it actually is.
| Big bore vs. Long stroke | Blazin72 | Engine | 32 | 12-03-2006 04:12 PM |
| Announcing the Crankshaft Coalition | Jon | Hotrodders' Lounge | 8 | 08-14-2005 05:56 PM |
| Forged Crankshaft - GM 6223 or Eagle??? | swerve | Engine | 5 | 04-14-2005 01:04 AM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
