Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - measure valve lift at retainer
Old 05-25-2008, 10:13 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
I don't understand why you have a dial indicator on the spring, but the lift measured there should match what you see at the lifter, with solid lifters. It sounds like your pushrod maybe flexing/bending slightly? Regardless, I'd do the checking with lightweight checking springs, or remove the inner damper spring.
Semper Fi
