Measured my cam today. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2003, 02:53 PM
59vette's Avatar
So today I measured the cam the results are as follows:
I/E Adv: 335/338 deg
I/E 0.05:231/238 deg
Lift(1.5ratio) I/E: 0.460 /0.488
Lobe center :114deg
Installed: 139 Intake centerline (ATDC) ???? (exh is at 89BTDC)
Seems a lot like the 327/350HP.
Problem is the 139 intake centerline.
I checked the measurements very carefully, and I'm positive that they check out.
Can a cam be installed to much wrong?
Also cheked the stall speed of the converter and it was only 1200-1300 rpm, WAY to low for this cam..if I understand things right....
Probably why 't cant keep alive in idle when put in drive....
Any thoughts appreciated...
Thanks
