measureing spring install height - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2004, 09:56 PM
Thumbs up measureing spring install height
ok what can i use to measure the spring install height?and can i use my stock springs to break in the cam and then install new ones?i think i found the perfect spring heres these specs
od/id:1.250/.875
max lift .550
seat pressure 110/1.800
open pressure/300/1.200
coil bind/1.175
what do ya think
thanks
Old 10-27-2004, 07:08 AM
King of my Man-cave.
Max usable lift for those springs is around .515-.520 lift. You can cut a piece of rod or dowel about 1/8" thick to the length of your installed height (approx 1.720", check the specs).
tom
