Measurements F1 Frame (Body Mounts) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2011, 08:57 AM
Hi I'm new here, I have a 49 F1 pickup that needs a lot of work. I pulled the Cab and Bed off the frame to repair some cracks and the body mount holes, the center holes where the cab mounts to the frame are wobbled out , I've made new pieces to repair the frame but need the measurement from side to side, center of holes before I weld them in. Thanks for any help you can give me.
Old 03-18-2011, 09:27 AM
All you need to do is measure across the bolt holes on the cab. There is quite a bit of slop in those mounts so they can be off a little.
Old 03-18-2011, 01:26 PM
Thanks Brian, I did that but there wobbled out to so was looking for the correct measurement so I can fix both. Thanks again for the reply.
Old 03-18-2011, 01:41 PM
Honestly, unless they are WAY screwed up you will usually shift the cab around a little anyway to align it with the frame. Honestly, unless there is a BIG problem with the hole it isn't a big deal if they aren't perfect.
1991 S-10 frame measurements, Help? 39chevy Suspension - Brakes - Steering 7 02-23-2009 07:02 PM
frame angles/measurements vistin Hotrodding Basics 6 11-17-2007 11:50 AM
Need frame measurements for '37 Plymouth hduff General Rodding Tech 3 06-18-2007 08:57 AM
35-40 frame measurements? Kruzin Karl Suspension - Brakes - Steering 2 06-15-2006 05:07 PM
Measurements of a shortbox chevy frame hugo` General Rodding Tech 6 01-17-2004 03:58 PM
