Measuring Fuel Pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2003, 08:49 PM
New Member
Hey all,
I have a 350 chev with a 650 cfm Holley carb and a stock mechanical fuel pump. I have measured the fuel pressure and got a reading of 10psi, so I went and installed a Holley fuel pressure regulator, which is pre-set to 7psi (well at least thats what the instructions say) and I have taken another measurement but I get the same reading.
Now my question is what is the correct method for measuring fuel pressure?
Currently I am letting the engine warm up which ensures the fuel bowl is full. I turn off the engine, disconnect the fuel line from the carby and insert a pressure gauge into the fuel line at the position where it normally connects to the carby. Restart the engine and leave for 10 - 20 secs. Is this the correct method, how long should you take the measurement for?
Any help would be greatly appreciated.
Waterhead.
Old 06-18-2003, 08:59 PM
WV hillbilly
Last journal entry: PTL 220CC
Re: Measuring Fuel Pressure
Originally posted by Waterhead
Hey all,
Waterhead.
if you have an in line fuel filter (between the fuel pump and carb) you need to check the pressure after the filter...
Old 06-18-2003, 09:09 PM
New Member
I have been taking the measurement from the end of the hose that connects to the carby ie. after fuel pump, filter and regulator.
Old 06-18-2003, 09:11 PM
WV hillbilly
have you tried to adjust the regulator?
Old 06-18-2003, 11:54 PM
New Member
No, not as yet as I wanted to make sure I was testing the pressure right first. No point going and changing the regulator if its not the regulator.
Old 06-19-2003, 03:43 AM
roys63's Avatar
You need to T into the line at the carb and adjust regulator running.
Old 06-20-2003, 10:54 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Waterhead,
You might be measuring back pressure, you should tee it into the line with it hooked up to the carb. In normal operation the fuel line would hardly ever have zero flow for any extended period of time. Also what type of regulator is it? I had a vacuum controled regulator years ago on a 351M motor with a Carter Super Pump. But when I would first start the engine I always had a higher pressure until the vacuum came up.
Regards
Mark
Old 06-20-2003, 08:39 PM
New Member
Thanks for your posts...I will go buy a tee section and measure the pressure and see how I go.
Thanks again.
