measuring push rod length??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 03:55 PM
i am in the middle of converting my sbc from a hyd flat tappet cam to a hyd roller cam with roller rockers. i understand that i need a) hardened pushrods and b)shorter pushrods. my question is this... how do i measure or determine the length for my new pushrods? any tips or advice would be greatly appreciated.
thanks keith
Old 07-07-2005, 11:53 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
tool
There is this tool.
Old 07-08-2005, 07:18 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
You will also need the geometry tool to replace the rocker along with the adjustable pushrod. There is a tool that you slide over the stud until it contacts the valve stem. If you have a standard length pushrod you can install it as well and see if it contacts the tool properly. If it is perfect it will just contact the tool when it contacts the valve tip. If it is too long the tool with hit the push rod and not the valve stem. If it is too short the tool will not touch the push rod. If you have the adjustable pushrod tool, you can just screw it out till the it contacts the geometry tool. Then just measure the tool and buy the pushrod closest to what you measure. Chances are there will be one within .005 of what you need.
Chris
Old 07-08-2005, 08:14 AM
In most cases, if you just buy the standard push rods for a sbc recieving a retro-fit roller lifter, it will be fine.
Old 07-08-2005, 08:26 AM
bracketeer's Avatar
489 Lemans
geometry tool
I was trying to find one of those and couldn't find one anywhere on the net. I know they sell them down the street.
Old 07-08-2005, 08:40 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Here is one. They sell adjustable pushrods too.
Old 07-08-2005, 09:31 AM
what is the standard retro fit length? is this length common knowledge for performance parts dealers?
thanks for all the responses.
keith
Old 07-08-2005, 10:01 AM
engineczar's Avatar
7.195 long is standard for a Hyd roller. If the geometry was ok in the old setup with standard length pushrods then the geometry in the new setup should be ok with the standard length for a roller setup. What I would do if I were you and don't want to buy (or make) a length checker would be to go to your local AutoZone or ? and buy a cheapy replacement pushrod for a roller motor (probably under $10) mock it up, and see how the geometry looks. If it looks good then buy the good pushrods.
BSE Racing Engines
Cheapest possible rod Nightfire General Rodding Tech 31 04-13-2004 09:06 PM
Any Benefit To A Light Wheight Fuel Pump Push Rod? Ghetto Jet Engine 2 03-10-2004 04:59 PM
Rod Length papabird Engine 0 07-07-2003 09:50 PM
302 chev rod length? Dave Y. Engine 2 09-22-2002 06:25 PM
push rod oil flow general Engine 4 09-01-2002 09:05 AM
