mech to elec fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2010, 02:43 PM
The mobile view is crap
I have a 1985 OMC 3.0 Liter in my boat. I have had fuel issues with it for the last 3 years. The engine was rebuilt when I bought the boat 3 yrs. ago. The previous owner told me that the boat had problems and he was just tired of it so he bought a different boat. I purchased the boat for a really good price and rebuilt the engine. After burning a hole in one of the pistons the first year I had it I haven't really messed with it. I am back at it now. I figure the piston got roached due to running lean. So I replaced the piston and paid a little more attention to the engine while on the water. The engine was still running lean so I replaced the fuel pump. The engine still runs lean. I replaced all of the fuel lines and had the carb rebuilt. The engine still ran lean and the last time it was on the water I had to be towed in (broke down on the water f'n sucks ***). I pulled the fuel line off the carb and rolled the engine over, and fuel drizzled out of the line, it was a constant drizzle. I changed the fuel pump back to the original one that was on it and it is doing the same thing. Is there a chance when the engine was rebuilt the lobe on the cam isn't large enough to properly pump the pump? My main question is I would like to set up an electric fuel pump but need to do it correctly and make it Marine safe. I would like it to be set up on an oil pressure switch but also am wondering if something else needs to be installed while going from mech to elec pumps. Is there a pressure switch that would shut the pump off? If someone could give me some advice on this or at least point me in the right direction it would be nice.
Sorry for the long post
Old 06-25-2010, 03:23 PM
SS66chevelle's Avatar
HR VIOLATION
I just installed an electric pump on my gen 6 502 and did a ton of research. This is what I learned:
1. install a pressure regulator with a gague on it as close to the carb as possible. If you are running a carburetor you only need 5 or 6 PSI at the carb
2. use a gerotor style pump like the holley HLY-12-125. do not use a vane style pump because most of the vane style pumps (like the holley blue, red, black etc) are not made for continuous duty and they crap out all the time
4. wire the pump using a relay (very important!!)
5. a dead head configuration is fine for a carb setup (no fuel return line needed)
Hope this helps get you started
Old 06-25-2010, 04:47 PM
302 Z28's Avatar
Very important, make sure whatever fuel pump you buy it is rated for marine use.
Vince
Old 06-25-2010, 07:09 PM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
all fuel hoses must be double clamped and fuel filter must be installed between pump and carb. brass ball valve at filter inlet helps when changing filter. you have changed the filter right?
Old 06-25-2010, 11:11 PM
ok, here is the scoop.
I went to the auto parts this past afternoon, well yesterday afternoon i guess but anyways i bought a carter electric fuel pump. It is a solenoid style pump part number P74019.
From the tank I have a fuel filter then the pump then another filter before the regulator then to the carb. Is this correct? Do I need the second filter? There is no filter in the carb inlet. I plan on wiring the pump with a 10 amp inline fuse also wired up to an oil pressure switch that carter recommends. The pump came with a wiring diagram so I am set on the wiring. I am just curious if this is correct. The pump is rated from like 5.5 to 9 psi at 30 gph or something like that. Will the pump shut itself off when pressure is built? Will it turn on and off constantly when at an idle or low throttle if pressure is met by the regulator? The engine is a 1985 OMC 3.0 Liter, If I understand correctly this is the same engine as the 2.5 iron duke. I am curious if anyone would know what to set my fuel pressure at or at least a starting point? Or even a minimum and a maximum then I can play with it from there?
Old 06-26-2010, 01:13 AM
You did check all the hoses from the tank to the pump, before you condemned the pump, didn't you? Now might be a good time to make sure you have good hose, that can withstand having a little alcohol mixed with the gas.
The fuel pressure sounds high to me. Remember, on a boat, if you put excess gas in the carb, and is spills. you are adding gas fumes that stay in the bilge, waiting for a spark, from the starter to explode.
Before radically changing the fuel system on a boat, make sure you are doing the right thing. Cars rarely blow up from a little gas spill. Boats do, way too often.
Old 06-26-2010, 06:54 AM
Are you vapor locking? The fuel lines aren't getting too close to heat sources?
Old 06-26-2010, 05:20 PM
when I put the new mechanical pump on I changed all of the lines going from the tank to the carb, I even tried running out of an outboard boat tank. The fuel pumps pump but it is just a constant basically drizzle from the hose. I am curious if the lobe on the cam is to small and just doesn't pump the pump correctly.
Old 06-26-2010, 05:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The pump cam can wear, as can the push rod if the engine has one, unusual because there isn't nearly the load that a cam lobe for a valve sees, but I suppose it's a possibility.
I'd check the push rod length to a new one as a start.
As for the electric pump, you want it lower than the fuel tank if possible or as near to this as practical.
A pump like you have is tolerant of dirt and etc., but running a pre-pump filter wouldn't hurt.
The regulator should also be near the carb, and set to about 5psi.
That said, I do not pretend to know what the CG regs are on such things- I'd have to advise that you bone up on the regs before doing anything.
Old 06-26-2010, 06:21 PM
I just put on an electric fuel pump, (bosch), because my fuel pump pushrod and cam lobe wore off. I put a hacksaw blade in front of the pushrod and held it up and had the wife hit the key. almost no movement. So, I put the inline pump on after a filter, and a clear filter ahead of the carb. Well, I was only getting a drizzle, also. I ran hose from the frame to the carb. Well, the hose doesn't fit as nice as the steel line did by the front of the engine. The hose was touching the water pump. I moved the line totally away from the engine, and hanging off tghe air filter, so far. Looks stupid, but it appears to be the fix. Oh well.
Old 06-26-2010, 06:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
With the oil additives being changed, we might be hearing more of this in the years to come. Good job figuring it out, anyways.
Old 06-27-2010, 11:44 AM
i have no fuel pump pushrod and the cam is only like 4 yrs old. if that. I mounted the fuel pump closer to the carb than the tank, there is maybe a total of 4 feet of line between my tank and carb. I mount the pump up on the engine because I would like to keep the pump from being submerged in water if I can. Is it really bad to have it closer to the carb than the tank running such a short amount of line. I guess my thought was that these fuel pumps are designed to push fuel like 15 or so ft. to the front of a vehicle.
Old 06-27-2010, 04:01 PM
I was working on an old '84 suburban. The fuel lines were spliced about halfway to the front. I mounted it there, but I also knew that when I pushed fuel up there with a little air pressure, it would have siphoned there all day; so I was tentatively ok with that.
Old 07-03-2010, 04:18 PM
ok, I had the boat in the water today with the electric fuel pump installed. The fuel pump is mounted close to the tank with about 16 inches of line running from the tank to the pump. The engine runs with the electric pump it would not run at all with the mechanical pump. When I got it out on the water I was running through the no wake zone and it was running good. When I got out of the no wake zone I opened it up to wot and she fell on her face after maybe 50 yds if that far. I flipped the engine cover back and a buddy was driving the boat. At wot the fuel pressure drops down to like 2.5 pounds. Should it maintain a 5-7 psi flow? Do I need a bigger fuel pump? After I would throttle the boat down for a minute or so she would take off again at wot for about 50 yds again. I can "troll" all day long I can do probably 15 mph all day long but I cant open it up because it runs out of gas
Old 07-03-2010, 06:38 PM
That's what happened to me, basically. If I hit the highway and accelerated, I fell flat. I would always start up again. Could barely accelerate. My hose just touched the engine and it was enough to vaporize the gas. My fuel is as far away from anything on the engine as I could make it: It seems to have straightened out. Or do you have some crud in your gas tank?
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 02:04 AM
sbc mech fuel pump install... Prof. T. Soggmeyer Engine 2 06-15-2009 09:38 PM
elec fuel pump wiring yragat Electrical 28 05-21-2008 06:52 AM
changed fuel pump from mech to elec - HELP! junkyard junkie Engine 16 09-19-2007 08:30 PM
93 dodge shadow fuel pump repair junkie Electrical 2 10-02-2003 09:05 AM
