mech fuel pump insulator on chevy big block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2012, 03:19 AM
Hello!
I'm just about to install fuel pump on my new build but have a question regarding the insulator, do big blocks using these as original?
Last time I installed a new pump was on a chevy small block and they had this insulator..
I don't know if you say insulators but at summit they are namned like that:
http://www.summitracing.com/parts/CTR-85-010/
What I mean is like a very thick gasket that I think should block from heat (I think?).
It doesn't feels like there should be a thick plate/gasket inbetween because without it is still is a pretty long way between when the rod lost contact with the mech fuel pumps lever arm and when it's starting to be contact again (when I turn engine over by hand while my brother holds the pump against the block).
with a insulator it feels like that the rod wouldn't push on the pumps lever arm for a long way enough.
Old 06-06-2012, 06:12 AM
DoubleVision's Avatar
I've always seen gaskets be used, but not these. Since the fuel pump rides on the side of the engine they get a blast of constant air when the vehicle is moving down the road. I can see how a heat shield would be a good idea but it's not going to help power any. Make sure you lube the spring area of the pump before you install it.
Old 06-06-2012, 12:01 PM
V305's Avatar
On the Border
I believe something like this is what you are looking for: Fuel pump seal
Old 06-07-2012, 08:35 AM
Thank for replies, if you haven't seen them, then maybe big block not uses these.. on the fuel pump seal link, it's look like it's the part "thermal gasket"
But with the fuel pump and the engine gasket kit there is only one thin gasket included
, but same thing on smallblock and they are using these
Old 06-07-2012, 08:49 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The SBC has a plate, the BBC pump bolts to the block. I have never had a need for anything else like a thick gasket/insulator.
Old 06-07-2012, 09:13 AM
How thick approx?
My gaskets are both very thin..
I can remember the sbc thick gasket to be like 0.5cm or thicker?
Old 06-07-2012, 10:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
How thick approx?
Not thick, like 0.035"-0.050".
Old 06-07-2012, 11:06 AM
Ok, thanks a lot!
I just mount it with the gasket included.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 08:36 PM
big block caddy fuel pump on fi motor sharkkill Engine 1 10-02-2009 11:40 PM
big block fuel pump? jake_arcticcat Engine 3 05-29-2009 12:49 PM
Mech Fuel Pump Que 39chevy Engine 3 04-25-2004 09:44 AM
mech fuel pump question Chevy_SS10 Engine 8 10-03-2002 08:52 AM
