mech fuel pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2002, 06:43 AM
Lightbulb mech fuel pump question
I am going from a tuneport setup to a carb setup...the new motor has a mech fuel pump. My plan is to diconnect the wiring from the elec. pump in the tank and pull the gas through the in- tank pump using the mech one.
My question is, since I already have a vent line (in-tank pump setup) , what do I do with the return line...do I leave it open as a 2nd vent line, or do I just cap it off?
Old 09-23-2002, 08:50 AM
bullheimer's Avatar
NEVER use credit cards!
Post
i dont think it would matter, but a cap would keep it clean in case you what to use it again. might want f.i. back someday, don't know,
[ September 23, 2002: Message edited by: bullheimer ]</p>
Old 09-23-2002, 09:01 AM
New Member
Post
why not use the electric pump,to me it does seem like the mechanical pump will pull the fuel thru the old pump right for the car to run right,i'm trying to say enough fuel.
Old 09-23-2002, 09:17 AM
Post
This motor is in my '95 S10 that originally had a 2.2L 4 banger in it when I bought it. I took out that motor and put in a tuneport 355, and used the electric pump in the tank. Last year I put in 377 and tried to use the elect pump with a carb, but discoverd since I was regulating the fuel from ~75psi down to 6psi, I was starving the motor for fuel at WOT, and forcing fuel past the floats . I was going to install a hi-volume, low pressure electric pump, but now I have to sell my truck (I need money for college), hence the reason I am putting the 355 back in. Since I ripped out the ECM and tuneport wires, I have decided carburate this motor, and save my tuneport for a dune truck in the future.
I used to work with a guy who put a 383 in his '91 Firebird, and had no prob pulling fuel through the elec pump, using the mech. I just don't remember what he did with the return line.
Old 09-23-2002, 03:38 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
given it to ya striaght, Plumb both lines into a tee fitting right where they come up into the engine compartment, then run the electric pump as you normaley would. This won't build enough pressure in the line to cause the the carb to overfill and will prevent the mechanical pump from running dry due to the restriction the in- tank pump will cause. Really it works! Been doing it for three years now.
Old 09-23-2002, 05:42 PM
Post
So the tee works like a bypass....whatever the mech pump doesn't need, goes back to the tank??? How many psi is the pump that you are using...just curious.
Old 10-02-2002, 07:02 PM
Post
Ddi you get my Email?
Old 10-03-2002, 07:37 AM
Post
No I didn't, but your trick works great....I tried to just pull the gas through the elec pump first, but it didn't work, so I bought a brass 3/8" (tube) tee, used a reducer from 3/8" to 5/16" for the return, and put the rubber hose on cut pieces of steel brake line (threaded into the tee). Thanks for the advise, you saved me a lot of hassle by not having to drop the tank and pull the elec. pump. I would rather invest $10 in parts, than drop the tank. Thanks again.
Old 10-03-2002, 07:52 AM
Post
No problem, Although this set up works pretty well I don't think I'll be running any more than 400 HP without dropping the tank and ditching the old pump. I'd be worried about fuel starvation under nitrous use as well. Glad I could help
