Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The mechanic didnt even know?
Old 04-11-2012, 02:53 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
To have the small black ground get that hot, (2) things must occur.
(1) the main large ground cable to the engine is not making good contact and
(2) something is shorted causing the small black ground wire to be overloaded.
I'm thinking the alternator was the cause of the short but what about the fusible link that is designed to prevent this very problem.
Have any of the fusible links been bypassed? This car has (3). Make sure the fusible links are installed as designed.
vicrod
