The mechanic didnt even know? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2012, 08:58 PM
tweed's Avatar
Hi guys im back.i was driving home one night last week when my tire rod came loose and there was smoke under the hood.i got it pulled in at a gas station of all places and notice smoke coming from the hood.the little ground wire from the battery to the frame was glowing and burning and smoke was boiling out of the inside.1999 jimmy 2wd that is.i call the firetruck and a man came quick and cut the battery because i dont know anything about cars/trucks.the guy saved my jimmy from burning to the ground but whats scary is the mechanic said that was the only wire burned up and the alternator burned up to and he dont know how,just said a fluke so now im in panaic everytime i drive it.anyone with any ideas?it cost $500 to put the screws back in the tire rod,replace wires and alternator at $65 an hour for labor.has this ever in history happend?
Old 04-10-2012, 11:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the main ground from the battery to the (usually) engine or a bracket attached to the engine wasn't making good contact, the electrical system could have been grounding through that one small gauge wire that melted.
Before it happens again, check the connections at the engine and battery and condition of the negative battery cable, along w/the positive cable condition and connection at the starter solenoid. If they're questionable, replace them. Be sure the grounds between the engine and firewall are there and tight.
Old 04-11-2012, 09:06 AM
tweed's Avatar
Well he did replace those wires from the battery to the fuse box to the starter and whereever else they go.he said the little ground wire was the only wire burned up.are there other wires i may need to check in there somewhere that may have a bad spot on them touching somewhere?the little ground was bolted to the body og the jimmy,thanks.
Old 04-11-2012, 01:53 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
To have the small black ground get that hot, (2) things must occur.
(1) the main large ground cable to the engine is not making good contact and
(2) something is shorted causing the small black ground wire to be overloaded.
I'm thinking the alternator was the cause of the short but what about the fusible link that is designed to prevent this very problem.
Have any of the fusible links been bypassed? This car has (3). Make sure the fusible links are installed as designed.
vicrod
Old 04-11-2012, 05:06 PM
tweed's Avatar
vicrod
Im not sure about what fusible links are im a car dummy.all i know is it didnt smoke untill the tire rod made that loud pop and came loose ubt ill check for wires with fuses.he did replace all the wires and said he ran it for 2 hours and it was fine.just scary him not knowing what would have causeed it.
Old 04-11-2012, 06:33 PM
SSedan64's Avatar
Old style look like a regular wire but, more flexible, normally 4 sizes smaller than the wire they're protecting.
Pics here will help you ID the different types.
http://www.procarcare.com/icarumba/r...ia_lights2.asp
http://www.google.com/search?hl=en&q...L4Wltwfu0f3PBw
Old 04-11-2012, 10:35 PM
evolvo's Avatar
Heathen
I have a ? what the ---- is a tire rod?
Old 04-12-2012, 04:07 AM
EOD Guy's Avatar
It would be the rod (link) that ties the steering geomerty together.
Old 04-12-2012, 05:13 AM
75gmck25's Avatar
On most GM vehicles you have a minimum of 3 grounds in the engine compartment.
1. Battery negative is grounded to the alternator bracket or the engine with a large diameter main battery cable
2. The engine is grounded to the body with a braided ground wire that runs from the back corner of the engine to the firewall area
3. There is a small body ground wire running from the battery positive over to the fender and/or radiator support.
It sounds like grounds 1 and 2 fell off, broke, or burned up, and your alternator was grounding through ground number 3 (the smallest wire). This small wire is not sized to handle the full alternator output so it started to smoke.
Check all the connections on grounds 1 and 2, and use a continuity tester to make sure they are not broken internally.
When a fusible link burns up you will get some smoke because the insulation on the outside is designed to be soft enough to burn as the wire heats up. The insulation will also be obviously very soft and the wire will be broken inside. However, it will not create very much smoke.
The fusible link on a 92 should be easy to find because it will have a large barrel-looking plastic section around the wire where it transitions from regular wire to fusible link. Figure 21 on this link has a fairly good picture of what it looks like and what happens when it burns out.http://www.procarcare.com/icarumba/r...ia_lights2.asp
Bruce
Bruce
Old 04-12-2012, 08:27 AM
tweed's Avatar
Thanks for all the help guys.im waiting for the mechanic to call back about this.i told the guy who left a note what you guys said.i dont remember seeing a fuse in the little ground wire that burned completly up to the bare wire.so ill take down notes from what he says and let you all know.maybe i shouldnt be so paranoid but i cant afford full coverage right now and cant afford another $500 little fire and the mechanic saying it was a fluke didnt help me any.
Old 04-17-2012, 07:24 PM
vicrod's Avatar
life is a ride
fused
A fusible link will not (should not) be found in the ground wire.
They are only used in the positive wires which is adequate to protect, in addition to the fuses, the vehicle circuits.
Any "real mechanic" will know this as just about every car built since (guessing) the 70's till the 90"s will have them. Then later, as more and more accessories were added fuses were employed which provides better protection of the vehicle wiring.
For piece of mind you may want to look for a new mechanic.
vicrod
Why Didnt My Paint Dry? My68Vette Body - Exterior 15 09-10-2010 01:04 PM
*help* hopefully i didnt fry everything hardonforsmallblocks Electrical 10 02-08-2009 09:32 AM
I didnt know where to put this............. Stinky General Rodding Tech 1 06-29-2003 06:11 AM
I bet you didnt know that....... 72 chevy Hotrodders' Lounge 4 03-21-2003 12:31 PM
I bet you didnt' know stonedchihuahua Hotrodders' Lounge 3 12-03-2002 12:33 PM
