Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mechanical advance settings??
Old 02-10-2005, 10:29 AM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
Vacuum advance
It took me almost an hour but I read every posting and article that you suggested. The distributor can go up to 51 deg but not on a running engine. The vacuum loss retards the timing back to mechanical total.
http://www.73-87.com/7387garage/drivetrain/hei.htm
14 initial + 21 centrifugal + 16 Crane adjustable vacuum advance with EGR = 51 total.
I understand that you set your distributor by it's maximum advance but I don't know why. According to these postings. If we were running at 38 deg total and both open up our throttles, you would drop to 35 deg and I would stay at 38 deg. I would be producing more HP.
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
Combining the 12 degrees of initial advance with about 8 degrees from the centrifugal advance and then adding 20 degrees from the vacuum can when operating at low throttle settings is just too much.. 40 degrees of total advance will probably cause pinging or even detonation.. That would be bad.
At 46 deg you would be on the next cylinder. That would be real bad.
http://hotrodders.com/showthread.php...ht=hei+advance
Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
I disagree with the statement of seeing 50 advance if you were going down the highway, (10 initial, 20 - 25 mechanical and 15 from the vacuum) you stated elsewhere when the mechanical advance kicks in the vacuum is not adding anything.
I also disagree with seeing 50 deg of advance.
http://www.gofastforless.com/ignition/advance.htm
Under high load, WOT, performance conditions there is almost no manifold vacuum so the vacuum advance does nothing.
http://hotrodders.com/t55364-15--hei%20advance--2.html
So if at say 2500 RPM, your total initial and centrifical advance is 32 degrees,and you are pulling a total of say, 36 with vacuum advance, when you start stepping down on the throttle, the vacuum advance will retard in relation to the loss of vacuum signal, to the point where, the 4 degrees of vacuum advance disappears, if enough vacuum signal is lost.
