Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mechanical advance settings??
Old 02-10-2005, 11:23 AM
Lthompson Lthompson is offline
THanks greatly guys. The carburetor im running says to set initial timing between 14 and 16. so ill probably use one of the other stop bushings. Ill just have to see what the recommended total advance is for that cam. I doubt ill be running enough vacuum to work the vacuum advance completely. ill just have to work with it all when i get to that point. Thanks again for all the help.
