Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mechanical Advance Timing
  #43 (permalink)
Old 10-07-2012, 12:03 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
You have the wrong converter for this 224 -106 LSA cam.
That is why it drops rpm in gear so much.
The 106 LSA cam needs 24 to 26deg initial timing and a 10" 3000 stall.
Shorten the timing curve to 10deg to allow this, using a screw with a bigger head diameter to restrict the advance travel more.
