Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mechanical Advance Timing
  #44 (permalink)
Old 10-07-2012, 11:00 PM
ggevaert's Avatar
ggevaert ggevaert is offline
Torque converter
Thanks! I'll play with the timing tomorrow.
The torque converter is a bit trickier as I have to order one, drop to the tranny, blah blah blah, you know the deal.
I think I need to read up on the torque converter and how it works as I know the basics but not how/when it kicks in when you have a 1500 vs a 3000. i.e. does putting a 3000 in gear do nothing when the idle is at 1000 or does the car try to move (my 1500 will try to move). Do you need to be reving at 3000 (or close to that) before the car starts the move. Not that familiar, yet, with workings of the torque converter when it comes to actually when they engage. Another area for me to read up on; exciting!
There was probably a good reason why the engine/tranny combo came with a 2500 stall.
When I destroyed the tranny pump, and therefore parts of the tranny, through improper spacing of the torque converter (another lesson learnerd) the tranny shop recommended/put in a 1500 unit. But they never asked what engine setup I have. jeez.
I did not pick the specs on this engine so what's the deal with this setup F-Bird88, is it a street/strip type of setup or more agressive than that?
I do want to be able to drive the setup on the road and I'm concerned about the high stall.
Thanks for all your continued help!
Ps. the mech advance stop will be much easier when I get my MSD 8365 in
