Mechanical or Electrical Fuel Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2003, 09:28 PM
lakecityg's Avatar
looking at a holley red or a holley blue electric fuel pump, and then a holley mechanical pump rated at 60gph. anyone have any recommendations for a mild street car? and is their any advantage to using a electrical pump as opposed to a mech pump?
Old 06-19-2003, 09:55 PM
superrodder's Avatar
On the street I don't use electric fuel pumps any more.they're noisy and extra work to install.And they offer no performance advantage in 99% of street cars.
mechanical pumps bolt right on and are reliable.no muss,no fuss, 1 less thing to worry about.
but thats just one grease monkey's opinion:p
Old 06-20-2003, 01:33 AM
Cool
howziit guy!
i replaced my EXPENSIVE MALLORY 140 electric pump/regulator, when it started giving me problems(noise/low fuel pressure).
since i have a mild BBC daily driver, i am so happy with the $20 NAPA mechanical fuel pump(1971SS model).
Old 06-20-2003, 11:10 PM
johnsongrass1's Avatar
Race it, Don't rice it!
A electric pump will give less pulsing pressure for a steady state of fuel delivery. a mechanical can float on you at very high RPM's reducing fuel pressure. Other than this a mechanical will be more reliable and normally install easier as posted before.
Old 06-21-2003, 06:46 AM
302 Z28's Avatar
A mechanical pump is no doubt easier to install, but more reliable, I don't think so. Just look at the millions of production cars on the road right now, built since the the late 80's with electric fuel pumps. An electric fuel pump not need to be noisy, if it is I would not install it on my vehicle. I am planning on an in tank electric fuel pump for my street rod. It will be no noisier than my 90 model truck, or my wifes 97 Tahoe.
Vince
Old 06-21-2003, 10:27 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I run nothing but Carter pumps, CRT-P4070 (5psi) or CRT-P4594 (7psi), both $60. Very inexpensive, very quiet 'cause they are 100% rubber mounted and 'cause they are rotary, not vibrators. Screw anywhere it is convenient on the frame, preferably near the gas tank.
Available at
http://store.summitracing.com/defaul...pump&x=21&y=16
