mechanical fuel injection - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2005, 10:14 PM
jalopy45's Avatar
Trying to size injectors for a 292 cube sbc, going to run alcohol with 13.5:1 pistons and vortex heads. Tried several mfg's web pages but can't find any tables or formulas. This is going to be used in a drag car. Also not sure which pump to use so if anyone knows of a web page or a manual that's available or the formulas to size these it will be appreciated.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 06-17-2005, 10:29 PM
camaroman7d's Avatar
You may want to get in touch with Inglese or Hilbourn. Do a search on the web and you should be able to find contact info. I know Inglese does some mechanical injection set-ups.
Royce
Old 06-17-2005, 10:34 PM
You can go to HRE.COM for info and even a manual that will have you tuning Nitro and Alcohol like a pro with the support to save you from melt downs.
You gonna blow it also?
Old 06-19-2005, 10:07 AM
jalopy45's Avatar
No blower, trying something new in my altered, using an Acell tuned port system with mechanical injectors, electronic ones flutter at high rpms and can't find anything to work with alcohol. Will check the website now, thanx.
mechanical fuel injection bondsman Engine 7 04-16-2010 12:24 AM
Fuel Injection vs. Carburetion Mad Maggot Engine 40 01-29-2005 02:09 PM
vintage Algon mechanical fuel injection c10_1965 Engine 2 03-03-2004 03:58 PM
Mechanical fuel injection?? colaus Engine 8 10-30-2002 01:25 AM
