Why?
Ontario Rodders |
It doesn't matter. Just put the rod in and bolt it up.
Ontario Rodders |
Well...I don't know. It seems to me to be easier to mount the pump with the rod as far into the bore as it will go so as not to have to fight the spring pressure on the actuating arm.
That and the old hacksaw blade trick...
I guess it would be a little easier. Another trick is, that you can thread a bolt in through one of the holes on the front of the block. That hole should go through into the cavity where the rod is. That will hold the rod up (no pun intended)
Just remember to take the bolt back out. Not sure if that bolt hole goes through on all blocks.
Ontario Rodders |
Don't screw it in too hard & bend the rod. And put a real short bolt back in with some sealer to keep the oil in afterward. Some people bend up a piece of wire to hold the rod up while slipping the pump arm under it. Sounds easier but I have not tried it yet.
Also...
You can use a bit of grease or assembly lube to hold the rod in the "up" position.
Ron |
