mechanical fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2008, 02:58 AM
should a fuel pressure regulator be used on 5 to 7 psi pump? if so does anybody make a regulator,fuel filter,and gauge in a one piece unit? also what rpm do you check pressure with a push rod pump? thanx
Old 04-21-2008, 06:05 AM
bondo's Avatar
Nope,....... It shouldn't be necessary,.... At All......
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 04:27 PM
E85 105octane pump gas Race Fuel Rob_E85 Engine 46 11-22-2007 12:55 PM
87 Suburban fuel pump help needed Mustangsaly Engine 14 10-29-2007 09:04 AM
Octane Booster Info SLR_65 Engine 46 09-30-2007 09:01 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
