Mechanical Fuel Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2010, 08:35 AM
Shag0215's Avatar
Tha Shag
I have a GM350 motor,the casting number says it was casted between 1980-1985.When i bought the motor it has a block off on the motor for the fuel pump.the motor that came out of my 1978 GMC sierra grande K-1500 was a small block 400.It had a mechanical fuel pump but it was mounted with a 3\16 or 1\4 spacer plate,will i need this plate on my 350??? I am not going to use the old fuel pump, i am going to buy a new one and a new rod,will i need the spacer on this motor or just mount the pump directly to the motor??
Old 03-12-2010, 08:46 AM
you need the spacer with the slot in it and you will need to get a fuel pump pushrod too. Pump will not mount directly to the block without oil pouring right out.
Old 03-12-2010, 09:47 AM
sqzbox's Avatar
My pipes are my music
Use the mounting plate and the rod out of the old engine and just buy the pump.
Old 03-12-2010, 10:23 AM
Shag0215's Avatar
Tha Shag
Rod quality questionable
My old rod has a little rust and some other buildup on it,if i clean it will it be good to use
Old 03-12-2010, 12:56 PM
sqzbox's Avatar
pump rod
I don't see a problem. Use some emery cloth and clean it. I painted my fuel pump mounting plate the same color as the engine, Chevy orange!
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 05:27 PM
Octane Booster Info SLR_65 Engine 46 09-30-2007 10:01 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 01:39 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 07:03 PM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
