Mechanical fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2004, 03:36 PM
Hello,
How much hp does a mechanical fuel pump with the light rod rob? I 'm trying to decide if I want electrical or mechanical fuel pump.
Thanks
Old 06-17-2004, 04:51 PM
CustomFord's Avatar
It hardly robs anything. The electric fule pump though can add more power and throttle response. Holley makes an electric fuel pump that works great. You can set the pump at the p.s.i. you would like it at and it's a pretty reliable pump.
If this is for an around town car I would just stick with the mechanical pump but if it's for a project that is for all go, I'd go with the electric fuel pump.
Old 06-18-2004, 01:20 AM
An electric pump "robs" power also, by way of the alternator.
Old 06-18-2004, 04:09 PM
So which should I go with, its a daily driver with drag racing on the weekends? Which robs the least amount of power?
Thanks
Old 06-18-2004, 06:53 PM
badknuckles's Avatar
you talkin to me?
the least amount of power???
the power difference here is something like 1/2 a horspower.
go with mechanical.
Old 06-18-2004, 07:00 PM
Sounds good to me, cheaper is better with me too lol!
thanks
Old 06-20-2004, 05:13 PM
docvette's Avatar
Wiki Edits: 12
Pump
[color=red]Doc Here
The only Absolute Way to gain a 0 hp robbing pump, is to go Electric run from a battery without a Charging system, (No Alternator) Of course you have to charge the battery Every night at home.
For about 1/2 to 1 horsepower... on a streeter, It just ain't worth the headaches...
Doc
[/color]
Aftermarket Solutions
Electronic & Electrical
Innovations
