Mechanical Fuel pump... 88 SBC (Picture) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-20-2008, 12:31 AM
Last journal entry: not a big fan of cherry picker...
Put pic up above of the hole.
  #17 (permalink)
Old 07-20-2008, 12:36 AM
SSedan64's Avatar
Don't understand??
  #18 (permalink)
Old 07-20-2008, 12:38 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
The camshaft choise, will vary, whether or not it has a fuel pump drive lobe on it.
The Truck I put that fuel pump on, had a flat fuel pump drive lobe.
  #19 (permalink)
Old 07-20-2008, 12:55 AM
The picture is on the first page it was just showing that it has the hole for the push rod... How do I determine which cam it has... my only quess would be push rod up the hole and turn motor by hand and see if it pushes...right or is there an easier way and right now this is little on the motor to turn it over with.
  #20 (permalink)
Old 07-20-2008, 01:04 AM
My 2 cents worth
Wiki Edits: 3
Get a push rod and turn it over by hand, if you are the only person around. It should have, at least, a movement of about 7/16".
  #21 (permalink)
Old 07-20-2008, 02:45 PM
boatbob2
fuel pump.
unless you are using F.I.,stay with the mech. pump.there is a plate with 4 bolt holes,,and a large hole for the pump arm to go thru. put permatex on block,then gasket,more permatex, install pump push rod, install plate with 2 bottom bolts. plate will stop push rod from falling out.
push the pump push rod,up into the hole,using balancer nut,turn engine til pump rod goes up all the way.in front of pump mount,(bottom left side of block) there are 2 bolt holes 5/16????? holding push rod up,(with finger) put bolt into top hole (of 2) and snug it,to hold push rod up,if rod slides down,snug it more.then install pump gasket,and 2 bolts ,to hold pump,remove bolt (holding push rod) replace bolt with shorter bolt. or you will have an oil leak. im not sure what bottom bolt is for,but,i always put a short bolt (with permatex) in both holes...have fun.
  #22 (permalink)
Old 07-21-2008, 06:21 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Originally Posted by carsavvycook
The block you have is for a fuel injected system. You will need to run a electric fuel pump. Your only other option, is to replace the block, and camshaft, to an earlier year.
Ummmm....what?
That block will obviously accept a mechanical fuel pump, slide the fuel pump pushrod into the hole, lock it in place by inserting a bolt into the appropriate place in the front of the block. install the plate listed in the link above, then install the fuel pump and back off the bolt in the front of the block.
Install a few flat washers under the bolt in front of the block and tighten it back down so it will be there if you ever need to remove the fuel pump. Just make sure you have enough washers to keep the bolt from touching the pushrod.
  #23 (permalink)
Old 07-21-2008, 06:25 AM
Double_v23's Avatar
As far as camshafts go, the one you have in there will most likely have a lobe for the fuel pump pushrod. if you are concerned that it does not then install the pushrod and turn the motor over and see if the pushrod moves.
Most camshafts come with a lobe unless the are a factory GM cam designed for motors with fuel injection.
  #24 (permalink)
Old 07-21-2008, 09:04 AM
Thank you for all the help... Definitely gonna go with the mechanical pump... My car is just a cruiser and have always had good luck with the plain ole mechanical pump. Although I did learn about relays, fuel plumbing, etc... This site is great... you start of with a small question... read a bunch of post... end up with five more questions... and learn 10 things fiquiring out your first question... If that made sense.
  #25 (permalink)
Old 07-21-2008, 09:10 AM
Jmark's Avatar
You might be able to score a plate and pushrod at a local machine shop too. They usually scrap their fair share of blocks over the course of a few years.
  #26 (permalink)
Old 07-21-2008, 11:33 AM
The 305 I am pulling out of the monte had the plate and the rod... Just have to inspect the rod... Again thanks to all who chimed in.
  #27 (permalink)
Old 07-21-2008, 10:55 PM
[QUOTE=boatbob2] snug it,to hold push rod up,if rod slides down,snug it more...................... im not sure what bottom bolt is for,but,i always put a short bolt (with permatex) in both holes...QUOTE]
Don't twist too hard when snugging up that long bolt. It only takes a tiny bit of pressure to hold the rod up, and only a tiny bit more to bend the pushrod. It'll bend much easier than you might think, or at least easier than I thought the first time I did it.
Those two holes in the front of the block are where '55-'57 motor mounts attach, and some later-model blocks have the bosses, but no holes. If that's the case, bend a piece of wire that you can use to hold the rod up while you set the pump in place with the other hand.
The rod will go farther out of your way with #1 cylinder in firing position.
conversion mechanical fuel pump to electric on 327 66 sting ray chuckycheese Engine 6 01-22-2008 12:50 AM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 03:36 PM
Mechanical fuel pump sb72elcamino350 Engine 6 06-20-2004 05:13 PM
SBC stock fuel pump sb72elcamino350 Engine 1 02-02-2004 07:13 AM
88 Mustang Gt Fuel Pump Help 406 ss monte Engine 5 01-13-2004 01:58 PM
