Mechanical Fuel pump... 88 SBC (Picture) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2008, 10:52 PM
Last journal entry: not a big fan of cherry picker...
They say a picture is worth a 1000 words...
SO I will be short... Fuel pump ----- Hole for Fuel Pump?
I am sure there is a simple explanation.
Old 07-19-2008, 10:59 PM
A little to short though...What is it you want to know?
Old 07-19-2008, 11:06 PM
Oh... How do I mount that fuel pump... the hole is much bigger. is there a plate?
Old 07-19-2008, 11:09 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
The block you have is for a fuel injected system. You will need to run a electric fuel pump. Your only other option, is to replace the block, and camshaft, to an earlier year.
Old 07-19-2008, 11:17 PM
Thank you very much... Sorta what I figured... But I can go with an electric fuel pump right?
Edit... sorry did not read your post fully... was looking at your vette... lol... Do you suggest a specific pump... possible one I do not need a regulator for?
Old 07-19-2008, 11:57 PM
Plate on the left, gasket on the right. But if there's not a hole drilled for the pump pushrod, or if there's a hole but it's not big enough, you'll have to go electric.
Old 07-20-2008, 12:01 AM
There is a hole... which is what made me think it was possible... Where did you get this plate?
Old 07-20-2008, 12:09 AM
My 2 cents worth
Wiki Edits: 3
I recently installed a electric fuel pump purchased at a local Kragen's. It is quiet, and it only put's out 6.5 psi. It was a universal fuel pump, that my customer bought. I was impressed about it's size, along with it being so quiet.
I was concerned it might over ride the Edlebrock Carb float, but it did not, and his truck runs great.
Old 07-20-2008, 12:12 AM
Where did you mount it? Engine compartment or back near the tank? Can I put it in the engine compartment or do you recommend putting it as close to the tank as possible... it is a 78 Monte Carlo and I would have to run a wire all the back....
Old 07-20-2008, 12:14 AM
My 2 cents worth
Wiki Edits: 3
You will have to get a fuel pump blockoff plate. Most parts houses should have one.
Old 07-20-2008, 12:16 AM
I have the plate... It was on the block when I pulled it out of my truck... TBI to carb conversion. Heads are all wrong(swirl head)... But it just an around the town summer car... new heads in a year or two...
Old 07-20-2008, 12:18 AM
My 2 cents worth
Wiki Edits: 3
Most aftermarket fuel pumps are pushers. Therefore they need to be mounted as far back to the tank, as you can mount it.
Old 07-20-2008, 12:20 AM
So wire the relay up in the engine compartment and run the one wire all the way back? What did you think of that plate up above? I have just never dealt with electric fuel pump and have never had a problem with mechanical...
there is a hole for the push rod... but you said earlier about the cam...
ID:	31349   Click image for larger version
Old 07-20-2008, 12:27 AM
My 2 cents worth
Wiki Edits: 3
The plate up above is for a mechnical fuel pump.
Yes you can wire the relay in the engine compartment, but you need to run a 14 gauge wire to the fuel pump. Mount it as far back to the tank as you can.
Old 07-20-2008, 12:28 AM
SSedan64's Avatar
Your block looks like it will accept a mechanical pump. You can see there's oil in the cavity & the pump rod hole. Here's a link for the mounting plate>
http://store.summitracing.com/egnsea...115+4294813113
conversion mechanical fuel pump to electric on 327 66 sting ray chuckycheese Engine 6 01-22-2008 12:50 AM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 03:36 PM
Mechanical fuel pump sb72elcamino350 Engine 6 06-20-2004 05:13 PM
SBC stock fuel pump sb72elcamino350 Engine 1 02-02-2004 07:13 AM
88 Mustang Gt Fuel Pump Help 406 ss monte Engine 5 01-13-2004 01:58 PM
