mechanical fuel pump issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2012, 05:32 PM
Can a mechanical fuel pump work intermittently? I have been having fuel pressure issues with my camaro. Sometimes it just looses fuel pressure for a while and you have to let the car idle for a while or feather the throttle a lot for it to come back. At first I thought it may be vapor locking but it did it the other morning when it was first started. I installed an electric in-line pump the other day but didn't get it all wired up. A while ago I was on my way to the store and it lost pressure again so I ran a wire to the electric pump and almost immediately got fuel to my clear filter so I assume it is not a line issue.
I am going to go ahead and put a new pump on it but I was just wondering if it was even possible for them to only work sometimes. I would have though they would be a go or no go item.
Old 08-19-2012, 06:44 PM
Last journal entry: Still running strong
Use the elect. pump to prime your carb.This is what I do, when I turn the key to the start position,the elect. fuel pump primes the the carb. with 7 psi. of fuel. then Ill give it a second or two to build pressure,then start it up.Dont need the choke.I yanked all of the choke crap out of the primarys.( Eddy carb.).You will have to use a relay.
Old 08-19-2012, 07:49 PM
It doesn't always loose pressure when starting it does it while driving too. I know these carbs are known for the gas draining back or evaporating in the bowls and making cold starts a pain sometimes. My dad has on on his 88 mustang and it takes a while to start after sitting due to this. My issue is more when driving then sitting thats why I am blaming the pump.
Chevy mechanical fuel pump moving TOO MUCH fuel? Torque454 Engine 1 11-04-2011 02:48 AM
Mechanical fuel pump by (race pump) 66nova383 Engine 2 10-04-2011 08:46 PM
Mechanical Fuel Pump Shag0215 Engine 4 03-12-2010 12:56 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 02:04 AM
Mechanical fuel pump sb72elcamino350 Engine 6 06-20-2004 06:13 PM
