Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mechanical fuel pump Problem
Old 02-05-2013, 12:35 PM
snakebit68 snakebit68 is offline
fuel pump
Sounds like the fuel pump cam lobe. Of course, check the plunger rod first to eliminate that as a cause. They are a relatively simple set up, so it can only be one of those two things...unless you are misfortunate enough to have purchased that many defective fuel pumps...doubtful! Make sure your lines aren't run backwards somehow or you'll be trying to pump fuel out of the carb into the tank.
