Mechanical fuel pumps - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2013, 10:43 AM
MalibuMike's Avatar
Which fuel pump would be a better selection in street use of a 496 BBC:110gph or 170gph?
Old 03-21-2013, 01:34 PM
Unleaded automotive gasoline weighs about 6.25 pounds per gallon, so you need to decide if your engine can burn 680 or 1,060 pounds of gasoline in an hour.
Bogie
Old 03-21-2013, 10:56 PM
In a perfect world you'd need to have just over 1/2 pound of gasoline per horsepower per hour. However, those flow numbers of the pumps are usually a free flow rating. Every bend in the lines, 45* fitting, ect will drop the flow also. The rating at a given pressure is much lower so for consistent jetting you need to maintain a consistent fuel pressure. So unless you know the flow rating at say 7 psi or what ever fuel pressure you run. Unless you know this I assume the pump will flow 1/2 of it's rating. So, Do you have a 650 hp motor or do you have more hp?
Using half the free flow rating might be overkill, but it's better to have more fllow than not enough
The Following User Says Thank You to tresi For This Useful Post:
MalibuMike (03-22-2013)
Old 03-21-2013, 11:50 PM
Banned
get the bigger one / run a regulator and a return line..
The Following User Says Thank You to gearheadslife For This Useful Post:
SBC mechanical fuel pumps keep going out highgrade Engine 9 03-03-2013 09:28 PM
BOTH Mechanical and Electric fuel pumps ericrcan Engine 22 08-12-2010 06:39 PM
Question on electric fuel pumps and fuel cells. eric32 Hotrodding Basics 14 05-11-2009 08:53 PM
Edelbrock/Holley/Mr.Gasket Mechanical Fuel Pumps lluciano77 Engine 4 05-23-2004 09:24 PM
Electric vs Mechanical Fuel Pumps slomotion Engine 2 06-23-2003 02:42 PM
