Mechanical to Hydraulic Clutch???????
I have a question about running a mechanic clutched tranny in a hydraulic clutch truck.
I am building a V8 S10, 350 SmallBlock(I know I know...) well it was a factory 4cyl,4spd truck. I was planning on running an automatic trans until I got a good deal on a Muncie 4spd out of a late 60's Chevelle. Here is my question, the trans in setup with a mechanical clutch...the truck is a hydraulic setup. I would like to keep the hydraulic setup to avoid having to fabricate a new pedal assembly,etc. Does anyone know of anyplace that sells or makes brackets to run a slave cylinder on the tranny? Maybe some wrecking yard shopping is in order...but what cars should I look at for the setup that I am wanting? This isn't anything that is needed right now, but I would like to get all my parts in order asap. Thanks for the help... Later, WEIMER |
I would highly recommend running a hydraulic through-out bearing. They are by far the easiest to setup. Howe Racing makes one that retails for $140 complete.
I have a hot rod shop, and have uses this setup with a chevrolet truck clutch mastercylinder several times. The pedal is easy to depress, very smooth. Try www.speedwaymotors.com for the bearing. Good Luck. |
