Mechanical oil pressure outlet for 302 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2010, 06:08 PM
cboy's Avatar
Last journal entry: Finished
If my memory is correct, the 351 blocks had two places you could tap in a mechanical oil pressure gauge tube, one at the stock position by the fuel pump and I think the other one was up near the top of the block back by the bell housing. The question is, do the 302 blocks also have access for an oil pressure gauge near the back of the block?
Always learning...and sharing what I've learned.
Old 03-10-2010, 10:06 PM
I can't remember cboy but i'll look tomorrow when I get to the shop I know a 302 has one up front. Maby some one else will know and let you know before then if not when I get home I will give a shout.
OLDROD
Old 03-11-2010, 07:26 PM
OLDROD
cboy my 302 is a 88/94 range block and does not have one in back of the block my oil stick is in the side of the block and not in the timing cover as some earlier ones. hope this helps as I see no one but me responded so far.
OLDROD
Old 03-12-2010, 08:15 AM
cboy's Avatar
cboy my 302 is a 88/94 range block and does not have one in back of the block....
Thanks for that follow up Oldrod. I was afraid of that. I wanted to avoid running my tubing from the gauge all the way to the front of the engine, but it looks like I'll have too.
Old 03-12-2010, 09:16 AM
onebadmerc's Avatar
I need a bucket of arc sparks
I have a 71 block I just looked at and it has a port, but it is not threaded and it looks like it would be under the intake. You got me wondering so I went out to my other shed and looked at my 68 block, and 85 roller block, they are the same. I then checked the engine in my 73 Mustang, it has a 78 block, it is the same.
Oil Pressure questions RObs71Nova Engine 22 05-02-2009 02:45 AM
lets have a oil pressure discussion k-star Engine 9 02-05-2007 12:31 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 11:27 AM
Low idle oil pressure chuckellison Engine 4 03-03-2003 08:20 AM
