Mechanical Oil Temperature Gauge question
I have an old Stewart Warner mechanical oil temperature gauge. The lead for the sending unit is a hard wire /cable but is too short since this is going in a Corvair and the gauge is designed for a front engine.
Do any of you know if there is a way to splice in an ‘extension’ so I could run the gauge all the way to the dash? The connector / cable looks the same as a mechanical water temperature gauge. Thanks |
Mount it on the shelf panel, facing forward, and read it in the rear view mirror. Problem solved. It'll read backwards of course, but you'll get used to it.
Thank you for the feedback, I will probably install it in the center console. It looks like I have enough wire to make it that far.
| Mechanical Oil Pressure Gauge Problem | beertracker | Engine | 4 | 12-15-2009 07:38 PM |
| oil temperature gauge | timemachine | Engine | 1 | 09-04-2007 08:46 PM |
| mechanical oil pressure gauge | hemigremmy | Electrical | 2 | 08-15-2007 10:07 AM |
| mechanical oil gauge bleeding? | cboy | Engine | 5 | 06-28-2005 04:37 PM |
| Oil temperature gauge | PAS55 | Engine | 4 | 05-24-2005 10:44 PM |
