Mechanical screw on temp gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2009, 06:44 AM
When I start a fresh engine I like to hook up an extra gauge for the water temp and oil pressure in the engine bay. The oil is easily done with a tee. The water temp gauge is a pain because of the long mechanical probe, so I coil it up as small as possible, put a couple of tie wraps and place it down on the intake. Then when the engine is broken-in, I drain some coolant and remove the gauge. So here's the question. Where can I find a gauge I can screw directly to the intake and leave it there as verification to the dash gauge? Anyone use one?
Old 06-07-2009, 06:52 AM
look on line at Grainger or get there catalog they have several types of TI that have pipe thread fittings with a short probe on them use them all the time at the water plant very accurate and durable
Old 06-07-2009, 07:47 AM
Look up Tel True in Rochester Ny they make what you want , should be about $35 to $40. They make all kinds of thermometers.
220 Temperture, Hot or Just Right? 2000jack Engine 74 06-13-2008 01:25 PM
tranny cooler spokesc Hotrodding Basics 22 12-23-2005 10:49 AM
Which temp gauge is more accurate Palmtrees57 Engine 3 10-30-2004 06:38 AM
Diff temp gauge? Jag Daddy Transmission - Rearend 3 05-25-2003 05:38 PM
1950 Buick temp gauge in engine stuck! reluctant_paladin Engine 1 04-10-2003 08:49 AM
