mechanical or vacuum advance - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2010, 05:53 PM
65ELCMO's Avatar
I'm building a 383 chevy, 4 speed, 3:73 rear, 3 Rochester 2G carbs. I am using a Mallory Unilite distributor. I have a mechanical and a vacuum advance distributor. Which one would work the best.
Old 05-27-2010, 06:00 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The vacuum distributor has both. That's the one you want.
cobalt327's Avatar
WFO
Wiki Edits: 1616
You want both vacuum and mechanical advance.
Old 05-27-2010, 08:01 PM
cool rockin daddy's Avatar
Noooooooooooooooo. Not this again! OP, please use the "search forum" feature and punch in "manifold vs ported vacuum". You'll love it. (hint, you'll want to run full manifold vacuum).
Old 05-27-2010, 09:37 PM
65ELCMO's Avatar
Ya I know that. I talked to a tech at mallory and he said the total advance was the same in both and I didn't need vacuum for a non highway cruiser. Just wandered what opinions are out there.
Old 05-27-2010, 09:40 PM
65ELCMO's Avatar
geeesss, lighten up. I didn't ask anything about manifold or ported vacuum annway.
Old 05-27-2010, 09:43 PM
ericnova72's Avatar
More for Less Racer
Better to have the vacuum advance and not need it or use it than to want it at a later date and not have it. Plugs stay cleaner and last longer with it, and gas mileage is better, so that is two pluses for it.
Old 05-27-2010, 11:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What are the specs on the engine? How's the vehicle used? Some details will help decipher the options.
I'm curious what a "non highway cruiser" actually is...
detonation 71 chevy c-10 Engine 33 04-29-2010 01:20 PM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 09:40 AM
carb tuning help needed biscuitville Engine 23 08-04-2008 08:49 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 01:51 PM
ignition timing bad502 Engine 21 02-20-2006 07:57 PM
