Media Blasters Check this out ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2010, 11:24 AM
outoftouch's Avatar
This is one of few options I have to choose from other than sand....
Can you tell me by the makeup if it would be decent for paint, rust removal from panels if used with the proper psi etc ?
http://www.olimag.com/PagesInterieures/jetmag_ang.pdf
thanks,
Old 03-23-2010, 11:45 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Looks like a decent material to me and I would use it..try starting at a lower pressure to see how it cuts and use the lowest pressure that works for you to alleviate warpage of the panels..
Sam
Old 03-23-2010, 12:03 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
jet mag is very aggressive . 7 mohs on the hardness scale. steel shot is 8 . i would look elsewhere somehow.
Kia fuel pump, again! oldred Electrical 150 07-15-2010 09:32 PM
Troubleshoot brake vacuum check valve 75gmck25 Suspension - Brakes - Steering 7 02-03-2009 07:38 PM
4l60E electronics check Mike_J Transmission - Rearend 7 03-14-2008 07:23 AM
Things to check out when buying a new car k2mooch Hotrodders' Lounge 7 08-17-2004 04:34 PM
Self Check Out //Fast Lane//-Stupid Ghetto Jet Hotrodders' Lounge 25 07-27-2004 08:29 PM
