Media Blasting
My projects won't fall into the class of hot rods by most of your subscribers but there are many similarities in any restoration project. I have a 1954 KR-175 Messerschmitt and a 1948 Fiat Topolino that I am restoring to "original". Both in need of major metal work, including media blasting. I recently purchased an Eastwood Soda Blaster and can't get it to perform as advertised (or should I say "expected"). So I was interested to see if any of your subscribers have purchased one and if they have good results how did they achieve them.
As far as your troubles with blasting....give us a better idea of what's happening. Is it just not working as fast as you hoped (maybe just a question of expectations)? Does it emit media erraticallly (maybe a problem with air supply OR media condition)? Or, what else is the complaint? Are you blasting large panels (the whole car, in othre words) or are you just blasting cracks, crevices and hard to get at areas? With a little more background, I'll bet you'll get some help. Good luck and welcome. |
Let us know what it's doing or not doing. I have one of these and it's pretty good for removing paint but is relatively intolerant of water or moisture in the air lines.
Soda Blaster
My first attempt with Soda was marginal at best. I may of had some moisture contributing to my problem since the compressor was in a garage (about 50 deg) and the blaster was outside in the driveway (about 30 deg). The media flow was intermittent at best and I had to "burb" it several times. I had an assistant shake the blaster while I controlled the gun and it helped some. Even so, it wouldn't remove the paint from my snomobile. I decided to try glass beads and traded out the soda retrofit kit back to the standard media kit. I fooled with it for about 40 minutes and out of the entire time I got about 15 seconds of acceptable performance, removing about 3 square inches of paint. However, it is encouraging to here that others have had more success. I appreciate any ideas?
A couple of possibilities. In spite of the billing that you can convert an existing blaster you really can't, at least not without completely cleaning the tank of all of the old media. The eastwood kit uses a restricted orifice to limit the flow of soda and coarser media will plug the restrictor. And it is almost impossible to clean the tank of all old media. Second the purge valve is just a little above the restrictor so that it's possible for a plug of wet soda to form where it can't be purged. First time this happened I took the valve apart to fix it. Then I realized you can just backflush hose with a blow gun. If you're having to rock the tank back and forth it sounds like the media is low. All of my pressure pot blasters do this. Once you get the media flow issues solved it will clean. My best results are with the soda valve on the bottom all the way open and adjust the airflow on the back near the regulator Start with it closed and open it a little at a time until it starts to cut. Once you get a place clear you can blast against the edge of the bare metal and it works pretty fast. |
Soda Blaster
Sounds like excellent advice. I will follow your suggestions and give it another try later this week. I am also making a dust proof (or dust catching) area in my garage to eliminate any extreme temperature/humidity problems that I may have introduced. I will post my results after I give it a try. Thanks again for your time in helping me resolve this frustrating problem!
Mike,
The biggest thing is to make sure your compressed air supply is moisture free. I soda blast in Alabama in August and haven't seen a lot of problems humidity. But water in the air supply deadly. 25 ft of copper line between the compressor and water separator should do it. |
Heres this drawing I made on air lines.
http://www.1969supersport.com/draw1.html Your getting moisture in your media. With the two cars your doing and the amount of time you will be putting in, I would suggest you get a supplied air setup as soon as possible. When your blasting metal you don't know what type of paint or filler or primer or sealer your blasting. Its all going airborne, so you should use caution on what your breathing. I won't even rattle can without it on. I use it for grinding, blasting, welding, painting, cleaning, etc. Once you get used to using it, you won't work without it. Rob http://www.1969supersport.com |
Media Blasting
Rob,
These drawings are great and further reinforce earlier comments shared on this subject. Your suggestion for a supplied air setup makes sense as well and while I'm making these other improvements I plan on doing this one too. Thanks for the assistance! |
Heres some reading for you Mike. I wrote this up on the chevelle forum a while back.
#4 Oct 9th, 08, 5:36 PM rubadub Lifetime Premium Member Rob Join Date: Mar 2005 Location: two rivers wi. Posts: 7,517 Re: ? on paint booths -------------------------------------------------------------------------------- In the first three pages http://www.1969supersport.com/paintroom.html You can take outside air directly into the paint booth Or take inside warm air mixed with outside air into the booth Or take just warm air from inside into the booth Or take cooler air conditioned air from inside into the booth You can also mix your paint by the opening and exit that air into the booth This is a negative pressure booth, in other words you don't have any fumes inside the garage, only in the paint booth. Its not a lot of negative pressure, if you leave the little service door open about an inch or two it will draw it shut. This is a really user friendly setup, your runner or the person mixing the paint outside the booth, will be breathing clean air, right after the initial mixing time. I use supplied air and I can step out of the booth and take a break and breath clean air in the garage in any kind of weather. Its all home made with cheap piping, and there isn't a lot of air flow going through the booth, however you will have a lot of fumes while you are spraying, but the person spraying can see what he's doing. A booth like this doesn't cost a lot of money to build, and it can be all unbolted and stacked up if you want to take it down. Its cheap, but you can get good paint jobs out of it, with the low flow you will have less dirt. Anyway Rob #5 Oct 9th, 08, 5:47 PM rubadub Lifetime Premium Member Rob Join Date: Mar 2005 Location: two rivers wi. Posts: 7,517 Re: ? on paint booths -------------------------------------------------------------------------------- A little more here, when I paint I turn the heat up to about 78 degrees, warm up everything really good, then spray between 72 and 76 degrees, I haven't had any problems with this set up. I think the warmer temperatures have quite a bit to do with it. I also leave the heat at 72 degrees overnight. We have sprayed z-chrome, (sprayable body filler) a lot of epoxy and other paints and primers, a lot of motorcycle sets and a few cars, however when it comes down to the final base clear, on a car anyway, I will bring in a painter that is currently working in the body shop field and paints on a regular basis, which is also good because he brings his own gun, the last one sprayed for around $15 an hour, thats a couple of years ago, so I might have to pay $18 or $20 for one now. With the price of materials I think its a good way to go. Rob __________________ "There are questions to be answered, and answers to be questioned" Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything. http://www.1969supersport.com Re: ? on paint booths -------------------------------------------------------------------------------- Just in case anybody is reading what I put out, heres how you build it. http://www.chevelles.com/forums/show...ld+paint+booth Rob __________________ "There are questions to be answered, and answers to be questioned" Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything. http://www.1969supersport.com |
Try this again on how to build a paint booth.
building temporay walls for a booth Heres some stuff on how to build some take down later paint room walls if you want to. On my site you can see some paint room pictures if you would like to, anyway, this is for the night owls on here, for what its worth. Start by laying out some 2x4's on the floor, this will be your bottom plate, so were going to start with one wall, you allready have the outside wall of your garage. Lay them flat where you want your wall in a line, one butted up against the other. Hilty them down to your garage floor every few feet, good enough so they won't move, don't over do it. Don't worry about the hilty holes if you decide to take the booth out, if you are, you can mortar the holes shut if your moving out permanently. If you don't tell anybody about the hilty holes in the floor, most people wouldn't even notice them. Build your wall panels on the floor, depending on how high your ceiling is, you want a half inch or so space between the top of your wall and the ceiling. I'll explain why later. I used 4'x 8' 7/16'' thick aspenite, smooth side facing the inside of the booth. Cut some 2'' x 4''s and lay them on there side, then lay your 4 x 8 sheet of aspenite over it and glue and screw the panels to the 2'' x 4''s. Only sheet one side, the studs will be showing on the side outside the booth. Go to the back wall and stand your first panel up on top of your 2 x 4 plate on the floor. Pre drill a couple of holes for lag screws to hold your wall section to the floor plate. Lag screw it down, now go the top of your wall section, and you should have about a 1/2'' gap between the top of your wall and the ceiling, it can be close to tight or an inch difference in the gap ,no big deal. Now locate your stringers or trusses or rafters or whatever, and pre drill your upper wall into the ceiling trusses. two if you can get them in, don't forget to level your wall section before you lag screw it at the top. Your not going to draw that top wall section to the ceiling, all your doing is putting a couple of lag screws in it to keep it from falling over. Finish out your wall as long as you want it, mines around 25' long I think. Now you have the wall in, and you have a gap at the top. Get some 1'' x 4''s or 1'' x 6''s and close off that gap, those are just screwed in also, nothing is nailed, so you can dissasemble all of it. I layed them up, then put a couple of screws in them to hold them, then took a pencil and marked them, pulled them off and put a little bead of caulk just inside the pencil line, then screwed them down and the caulk squished out, and smoothed it off with my thumb. Do the same to your bottom plate, also caulk the cracks in between the wall sections. Then some cheap white latex paint on the inside and it will be water proof so you can hose it down if you want to. I'm thinking with this, plus the paint room section, you should have a rough idea on how to do it. I'm guessing, but I think I could dissasemble my paint booth in an hour with an air ratchet and stack it up and put in the back of a pickup. Rob |
Heres some pictures of me in supplied air. Anyway whatever.
http://www.1969supersport.com/restore7.html Rob |
| All times are GMT -6. The time now is 05:35 PM. |
