media question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 05:45 AM
just another car guy's Avatar
Last journal entry: 50 chev p/u project
media question
Does anyone know where to get crushed walnut shells for media blasting & also you just use a regular sandblaster right ?
Thanks
Dan
Dan
Old 01-21-2006, 07:37 AM
jim..'s Avatar
That 6 Cylinder Guy
You can get walnut shell from any good abrasive supplier,I get mine in pallets of 50 lb. bags at about $17.00 per bag,before shipping,you will probably pay more buying single bags.
It comes in coarse,medium and fine,if your doing metal,get the coarse as the finer grades are not agressive enough,also walnut shell will not remove rust,it is not hard enough,even some paints and primers cannot be taken off with it.
I blast log houses with it,check it out.
www.woodblaster.com
Old 01-21-2006, 08:45 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
blasting requires a lot of cfm not pressure. to give you an idea i have 185 cfm compressor and run 1 1/4 hose with a 3/8 nozzle. i use acrylic and starblast
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
Hotrodders Guidelines -- READ ME Jon Suspension - Brakes - Steering 0 06-14-2003 05:03 PM
Hotrodders Guidelines -- READ ME Jon Electrical 0 06-14-2003 05:01 PM
