medical nos - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2010, 01:08 AM
BLZR81's Avatar
medical nos
i can get medical grade nos for free. i want to know if i can use it in my nitrous oxide system. i have a super power shot.
Old 01-23-2010, 01:43 AM
DoubleVision's Avatar
Yes, you can. The difference is, automotive grade nitrous has hydrogen sulfide so it can`t be inhaled or huffed for recreational purposes (read: getting smashed) Other than that, they are pretty much the same.
Old 01-23-2010, 01:48 AM
BLZR81's Avatar
thanks, this is my first time using nos
Old 01-23-2010, 04:11 AM
ericnova72's Avatar
More for Less Racer
Yes, you can use it, no different than the performance grade nitrous other than the mentioned anti-huffing additive.
Legally you can get in trouble having medical grade in your possession if you don't have the proper medical permits, but this is only if the law wants to target you on this fact. Don't get caught providing it to anyone who might misuse it as a recreational drug
Old 01-23-2010, 07:32 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I used to own a (N.O.S. brand) cryogenic nitrous pumping station. Nitrous +, or racing nitrous, has 200 ppm of sulphur dioxide in it to prevent abusing it by human consumption. It causes nausea and if enough is consumed, even vomiting, but is not enough to effect performance in any measurable way. But let me tell ya a little secret about "medical grade" nitrous. It often has water in it. Hospitals and doctor's offices filter the gas pretty well and the way it's pulled from the bottle doesn't remove the moisture, so it stays in the bottle, and they don't empty it when they fill them. So when you turn the bottle upside down to get a liquid nitrous transfer, the first thing that passes through is any water that happens to be in the bottle. That happened to me twice using medical grade, which was only because twice, my gas supplier didn't have NOS+ on the truck, only medical grade. I didn't know it happened the first time, because the customer I sold it to didn't use his system for a while, but the 2nd time, I found out almost immediately, then found out about the first time later. I would stay away from medical grade if I were you, or at least take steps to make sure you drain the moisture from the bottle before doing a transfer.
Am I able of running NOS on this build ?? 350cruiser Engine 2 07-27-2009 12:01 AM
Nos question Ratoflic Engine 4 02-03-2005 07:52 PM
NOS with alcohol The Vandal Engine 4 03-28-2004 02:53 PM
Should i NOS or not? Mickey Spillane Engine 4 07-20-2003 01:11 PM
SBC NOS piston question..just how much? Dave Y. Engine 2 11-19-2002 06:16 PM
