Mega Raptor 700r4 ??
8K views 15 replies 7 participants last post by  x007
hi,
Someone know someting about mega raptor trans ?
http://www.transmissioncenter.net/700megaraptor.htm
I want to know if its a reliable source ?
Reliable product ?
I have a turbo 350 currently and may be the trans will not last whit 800hp+ engine and if i change i want to go whit a 700r4 to have the overdrive like original one.. I have a 700R4 in hand but its stock so i dont think it will be strong enough..
Or anyone have a sugg. to buy the best 700R4 possible ?
#6 ·
fordSR said:
Don't buy a Mega Raptor 700R4. I own one and would'nt buy another. Buy the heavy duty parts and have someone in your area build it for you. Do a search for this company (PATC) Raptor 700, etc, on this forum, this subject has been discussed before.
I have done some search but nothing that can help to make a safe choice as now...
I have found couple of place for 700r4 and still trying to find/choice a reliable one... I have seen bad comment on google about ArtCarr still looking for more info..
http://www.700r4.com/
http://www.artcarr.com
Any other info appreciated...
As of build one locally, i dont know a knoledgeable place i can trust for a Hi Perf. transmission as now near me..
#8 ·
ronb said:
If you are planning to run more than 500 hp? you might want to look at a 4L80E or turbo400 instead? a 700R4 cannot take much more than 500HP! :rolleyes:
This where i am right now...
Turbo 400 doesn 't have and overdrive,
4L80 should be the answer 3800$ outch...
And the problem is : does a 4L80 will fit in my Transam 1984 ?
As i understand, the 4L80 would be manual body, this mean i will have to shift , no more automatic.. No prob whit that, i have already a B&M shifter that can do this and fit this trans...
The problem is, No after market crosmenber found... and i have a sponh tork arm to adapt as well... Lot of fitting to do... and not 100% sure this will fit my T/A 84 ???
More info will be appreciated if anyone can help on that...!
#9 ·
The 4L80`s automatics were installed in chevy 1 ton trucks(dualy`s) around 94 and up ! if you can get one of those I`am sure there is a stand alone aftermarket device that will control the shift points ? the other option is the turbo 400 with a gearvendor under/over drive unit? I have one installed in my 88 T/A which as you know is the same Gen F body as your`s? see my photo galery!
#10 ·
I found the baby !
Fully Manual !
same guys that build the mega raptor
http://www.transmissioncenter.net/4l80e.htm
4000$
But i have to build a custom crossmember, no one do a crossmember for this trans. on a F-body 82-92...
but i will go for it and build someting custom... Just need to store some money before... I think the Quadzilla would be my choice i want the overdrive very mutch :thumbup:
#13 ·
engineman302 said:
if over drive is all you need for a tb400 try the after drive products.
http://www.gearvendors.com/
may be i'm wrong , but in my opignion its impossible to put this on a F-body...
This is far too long.. Need room for the tork arm... And at 2200$ i would go whit the manual 4L80 i think..
Crosley : the torque is a custom build can handle nitrous & supercharger up to 1200HP !
#14 ·
it is all steel, you cut and weld it. Need more space for the tranny? Cut the floor aout , then replace it..... I did this on my 1961 Dodge Lancer that I installed a small block chev & t-350
the torque arm..... build a custom one. It is done all the time. We built a custom torque arm for a Firebird diff under a 48 Buick
#15 · (Edited)
It will fit! with the torque arm instaled! as i stated earlier in this post I have this unit instaled in my 3rd gen T/A! it is tight! but it fits! :smash: Also I would like to add chevy instaled the gearvendors at the factory with a turbo 400 on the Caloway corvette in 88-89 because the 700R4 could not handle the beefed up engine! the only overdrives available where the 700R4 and 2004R back then!
#16 ·
By curiosity, can you post some pics of your setup ?
I run whit a spohn tork arm and seeing the free space i doubt i can fit this here unless i cut the tork arm etc.. (& i dont want to do that)..
