megasquirt question - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 01-11-2012, 08:29 AM
Banned
megasquirt question
I bought a used ms1 v2.2 with a flyback board but the flyback board was cut off. How do I rewire it on and is there any disadvantage to reconnecting it? I can't think of why he would have cut it off.
Name:	2012-01-11 06.20.02.jpg
Old 01-11-2012, 06:34 PM
LATECH's Avatar
They sell this preassembled or as a kit you put together. If you can get the instructions sheet for it, you should be good to go.
Or if someone has one that will post a pic of the inside, you could use that to determine your connections.
or maybe this will help
http://www.bgsoflex.com/megasquirt.html
Or look around. Maybe they can e mail a guide or assembly guide or ??
Actually I just looked again and the full assembly guide is listed in the menu on the left side of the page.Good luck
Old 01-12-2012, 03:39 AM
Project89's Avatar
u wont need the flyback board unles su plan on running low-z injectors i belive
Old 01-14-2012, 10:19 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
My understanding of flyback is that it is better to have it in any case. It is suppose to speed and better control injector timing. I am rusty on this, but from what I understand the injectors basically recoil energy back into the circuit board when they open and close. This energy needs to be redirected, usually back to ground. I used to have a better grasp on it, but I have not looked at a schematic in at least 5 years.
I would go to the megasquirt board and ask there. They will be able to help and give better answers.
Old 01-14-2012, 12:22 PM
LATECH's Avatar
X 2 what TurboS10 said. For low impedance injectors it should not be necessary, but it does speed the closing of the injectors making Idle speed control a little simpler and better quality.
Also if you intend to install nitrous and a second injector on each cylinder it is a must to have as 2 injectors increase the flyback voltage when the injectors are turned off.
Recent Modern Electronic Engines posts with photos
Megasquirt AVR Rawden Introduce Yourself 1 07-28-2007 04:01 PM
what is megasquirt? kuhn-77 Engine 8 12-23-2006 08:24 PM
Megasquirt EFI???'s RJL Engine 2 03-26-2005 09:13 AM
Megasquirt atlantis Engine 8 01-12-2005 01:04 PM
Megasquirt ECU TurboS10 Engine 11 09-26-2003 08:15 AM
