Melling cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2003, 04:47 PM
Post Melling cam
Does anyone know anything about a Melling SS396 cam. I had it in a stock oval port 454 and it ran good. It's now in a square port 468 with 11 to 1 comp, a GM 2 plane manifold and a small holley. I haven't ran it yet, will it work well with square ports?
Old 03-29-2003, 12:17 PM
BOBCRMAN@aol.com's Avatar
Post
your new big block could use a lot more cam than the Melling.
Old 03-29-2003, 03:53 PM
Post
This engine will be going in a '70 nova and will be more for show than racing. Will this cam be capable of enough rpms for the heads to work? Melling says this cam has .520 lift and 222 deg. duration @ .050 (don't know lobe centerlines). This engine has closed chamber heads with 11 to 1 comp. if I go to aluminium open chamber heads how much compression will I lose and will it run on pump gas?
Old 03-30-2003, 02:59 PM
woodz428's Avatar
Troll Hunter
Arrow
For the use you plan, I think it should be able to pull plenty of rpm. I think you would have a lot fatter power band with the new combo than with the ols one.
