melling oil pump screen - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2009, 03:28 PM
Hi Guys; I am changing my oil pump in my small block chevy. I purchased a Melling M55HV pump and S-55 screen assemb. The problem is I have a 7 Qt. pan and the screen does not go down even as deep as the stock chevy pump-screen. Should the screen be installed deeper in the pan?If so the screen is no longer flat that does not seen right. What am I missing?? Thanks for your help!
Old 11-11-2009, 03:38 PM
You need to buy a new pickup tube for that pan, and for a high volume pump.
Old 11-11-2009, 03:48 PM
Thanks for your responce, I have not found where the new sceen for the deep pan can be located. Ane help?
Old 11-11-2009, 03:51 PM
Where did you get the pan? Do you have a part number?
If nothing else, you should be able to measure from the pan rail to
the bottom of the inside and find one that way.
Old 11-11-2009, 05:41 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Here, look on the left side and pick your pan depth. Make sure to select a HV pickyup.
http://www.summitracing.com/search/P...il+pump+pickup
Semper Fi
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
hv oil pump jgh64pkup Engine 18 04-27-2009 11:06 PM
Chevy Small block, low oil pressure and ticking? Help.. Bowtie_Boy89 Engine 2 02-25-2009 03:52 PM
What oil pump would be good for 350 SBC? Heard bad news about melling eric32 Engine 10 02-15-2009 02:48 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
